#11
As Linux costs nothing in opposition to the Windows license, Asus compensates that with 10GB of extra SSD hard disk on the Linux model. That is a real alternative for Windows, at least for a netbook as the Eee. If other OEMs would take that route, that would be another scenario. I don't remember what distribution it is based, but anyway the distro is not the important part: the polishing that they have done to it, and that all is working out of the box is what matters for what we are discussing here. |
#12
They need to promote the Linux models they do have better - since they are cheaper and suitable for the majority of buyers when set up right, people should be buying them... |
#13
#14
I always loved AT, even when he was back at the inq and would write snarky stuff in your comment at the end of the article when he reviewed and accepted it for posting.
It's good to see that he is a irreverent as ever.
Linux is only free if your time is worthless. |
#15
Ubuntu 9.10 isn't anywhere near as old as XP
#16
As a long time linux user I can safely say that windows is pretty unusable to me.
#17
Well, even if my Xp pre SP1 Enterprise version wouldn't recognize more than 128(?) GB of my SATA disks, it would find them and install to them.
Problem with this was that Ubuntu wouldn't even do that. It found 1 of 3 disks and didn't find the boot drive. (MBR or whatever.) With Xp at least I got to the desktop so I could run WinUpdate and fix it. (By extending the partition.) I'm sure Ubuntu is fine once you get it running, but as a replacement to win or macos, they first has some work to do. Don't forget the masses want it simple. If they want it complicated they marry. |
#18
I find it hard to believe that they would forget to put SATA drivers into installer in the latest version of Ubuntu.
#19
They didn't. Period. Unless they ripped them out, SATA has been there since 7.something.
Also @Dudler, try installing XP or vista on any modern hardware, then try Ubuntu. Ubuntu is MUCH easier and faster. -Charlie |
#20
Windows 7 installs surprisingly smoothly. I even suspect they've been inspired by Ubuntu. XP's continued lack of support for installation on SATAs through the years was...flabbergasting. Insane. Inane.
| Tags |
| fud, linux, macosx, pseudo-review, review, windows |
| Thread Tools | |
| Display Modes | |
